archer-ian
- Mar 12, 2006
- 12
- 5
Engine misfires like mad when under load, usually at about 2,500 revs. Now its getting worse with the colder mornings, misfiring on idle till it warms up. Pulling off each HT lead in turn makes matters worse, I thought maybe a lead was breaking down. First started about 6 weeks ago after battery was changed. Have tried resetting ECU by disconnecting battery over-night. Local Fiat mechanic put computer on to ECU but didn't really show anything concrete. He suspects the MAP sensor is duff. Coil pack replaced 6 months ago for not firing on no. 3 cylinder.
MAP sensor Bosch part number is 0 261 230 035. Any comments on the diagnosis and where's the cheapest place to order a sensor. BreakersWeb.com want £42.50 ex delivery for a used one.
TIA
Ian
TIA
Ian
