lumpmonkey
- Oct 15, 2006
- 8
- 3
I'm clutching at strawst trying to find the cause of the problem, before I take it in for a diagnostic I'd like to try all possible diy angles!
Car is Fiat brava SX80 1.2, 2000 reg. Engine management light came on, flashing at first when under acceleration, now constant. Acceleration is extremely sluggish, verging on severely handicapped! Cruising is fine, it's just when the engine is under extra load it seems. It's most severe when going up hill, but if I put my foot down even on the flat it starts lurching!
So far, I've tried the following:
1) Removed air filter, checked path between air filter and intake vent ok. Air filter is fairly new, looks cleanish.
2) Removed and reseated each HT lead. With engine running unplugged each lead in turn, noticeable drop of engine revs with each lead. Not exactly the same level of drop, but hard to quantify by ear! Each lead had an impact on the engine anyway.
3) Tried to get at the fuel pump to check the filter, by this time daylight just about gone and couldn't see anything quick to try so gave up!
Things to try next:- Test impedance of lambda sensors, expect lowish ohms for the heater elements? Test injector impedance,14-15 ohms?
Does anyone have any other suggestions?! Any advice greatly appreciated
