I have a very well cared for 1.4S on a 'S' reg, with 67000 miles, and lots of servicing.
On Saturday night I left it on idle for half an hour while I was elsewhere (don't ask). On return, it wasn't idling properly. It's hunting, but the revs don't rise, they fall away, then return to normal, in a cycle. This problem is now only intermittant at traffic lights etc.
Also now during partial acceleration the engine frequently can be felt to skip a beat. But only under partial acceleration, full acceleration is fine. It did this all the way home from Fort William yesterday, as that's were I left it idling; thats 120 miles from home so a considerable drive.
Mpg is fine. No actual misfiring. So the questions are:
a) Can the idle control valve affect the car under acceleration, as well as idle?
b) What are the odds the low oil pressure at idle has goosed the engines top end (the cam visible under the filler cap looks fine).
c) Any chance it's another problem with the engine management system?
What would you do next if you were an able home mechanic?
Jeff
P.S. Engine temp fine, no warning lights on.
Jeff
