thepieman
I’d like to know more about the ECU, what it actually does, as a newbie to all things Fiat I am reading various articles regarding the above.
My understanding of the ECU, is that it’s the engine management system correct!
As such I’ve also read on the Bravo Guide that if you remove the negative lead from the battery terminal for a certain amount of time; the system, when the lead is reconnected will set itself back to factory defaults.
I’m also of the impression that this system when reset will start the learning process again e.g. how and individual drives that particular vehicle.
With that in mind, would it not be an idea when buying a Bravo/a second hand to actually reset the ECU?
I suppose what I’m getting at is this, the vehicle has been driven from new in a particular way by one owner; the system has adapted to that style of driving it’s then resold to a second party, now does the system continue to adjust for that new driver or is the previous drivers’ style and handling locked into that system?
I’d also like to say that in the few weeks that I’ve owned my Brava, I have come to regard this forum and in particular this section as gold, there are some really knowledgeable people out there.
With that in mind, I’d like to make an off-topic suggestion here I know there is a guides section, but it isn’t that obvious until you see the link, what I think would be ideal is a “New to Fiat?” “Read this first” section, which consists of how tos and information about the ECU or cam belts etc…
Fiat Brava 1.6 16V
Fiat Brava 1.6 16V
