| FIAT BRAVO 1.8, 16v, HLX Hi im going to look and one of these tinight is there any probs i should look out for?
| | #2 | |||
| Re: FIAT BRAVO 1.8, 16v, HLX
2. Check the alarm and RCL working off the key. 3. Check the heated seats work and aircon if it has it. 4. Check rear wiper motor works, common fault. 5. Has the cambelt been changed, any records? 6. Check usual signs for wear and tear i.e tyres and suspension. 7. Check the clutch out for slipping. 8. Might sound silly but make sure all the lights work on the car and indicators as the stalks sometimes fail and cost £150 from Fiat. Thats the main things i can think of. But obviously make sure its not been abused, if everything looks good and well looked after and the electrics are ok you should be ok with it for years to come.
__________________ ![]() ePER 4.0 DVD 2008 / Fiat Bravo Haynes Manual / Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual in Electronic Format. £5 Delivered. | ||||
| | #3 | ||
| blessed are the apostates | Re: FIAT BRAVO 1.8, 16v, HLX check the abs light comes on when starting car and then goes off shortly afterwards, same for airbag light, and injection light. if any dont come on at all it may mean there is a problem that has been hidden by removing the light on the dash. if any stay on it means there is a fault, could be expensive. the airbag light is a very common issue and not a big problem, but can be used to haggle price down. | ||
| | #4 | ||
| hot hot tamale! | Re: FIAT BRAVO 1.8, 16v, HLX Check under for any crushing of the underside. There are specific points where the car should be jacked up and almost no garages seem to know this and they just throw their jack in wherever they can..
__________________ | ||
| | #5 | ||
| Re: FIAT BRAVO 1.8, 16v, HLX Well just to let you all know i got the car and its very clean - will try and get pics up tomorrow as its dark now the car is a FIAT BRAVO 1.8, 16v, HLX ABARTH (is abarth a limited edition or somthing?)
| | #7 | |||||
Yea and on the seats
| | #8 | |||
__________________ ![]() ePER 4.0 DVD 2008 / Fiat Bravo Haynes Manual / Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual in Electronic Format. £5 Delivered. Last edited by JoskeJTD; 03-10-2006 at 22:54. | ||||
| | #9 | ||
| Re: FIAT BRAVO 1.8, 16v, HLX yea thats the same skirts and bumpers mine has on
| | #10 | ||
| | sammiboo | Bravo / Brava | 255 | 28-02-2008 23:34 |
