The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 25-09-2006   #1
Trader Rating: (0)
Brava Flasher Relay
Hi guys,my mates Brava is having werid problems with his indicators,if he puts them on instead of flashing the orange lights just light up and stay on,same with hazard lights too,so we pulled the flasher unit from the glovebox,didnt really do anything with it,and put it back in and bingo!,it worked,but 2 days later it had gone back to just staying on!
so my question is...is it the actual relay that is goosed,or does it sound like a loose wire after the relay?
contacted fiat dealer and he was going on about some really silly prices!
any help would be great guys!
cheers in advance!
p.s. also are the flasher relays all the same across the range,ie punto,cing,etc?
cheers again!
life is the fabric of thought,woven into the loom of the mind
Mr_noir_1976 is offline
Old 26-09-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: Brava Flasher Relay
it sounds like a relay problem to me, because it would have to be a strange wiring fault to keep the relay open. go to a scrapyard and take a relay off any bravo brava or marea. should cost £1-2.
jug is offline
Old 26-09-2006   #3
Trader Rating: (0)
Nice one!!!
But but does it have to be bravo,bravo ,marea?,
i mean would a punto or any other fait be the same?
Top Man!!!
Old 26-09-2006   #4
jug
jug's Avatar
Trader Rating: (1)
dont know, but you can simply remove the old relay and make a note of the relay map on the top of it (or take it with you), most relays are the same. the relay from a mercedes or skoda or anything would probably be the same, or at least fit and do the same job.
i only said bravo brava or marea because i know its the exact same relay because they're basically the same car.
jug is offline
Old 27-09-2006   #5
Trader Rating: (0)
Cheers matey!
im off to the scrappy!!!
hopefully ill be fully flashing on my way home!
ohh err missus!!
lol
(S) Brava Bodykit bravaboy Bravo / Brava 4 14-10-2006 19:46
(G) 2nd Hand Brava SergiuRO Bravo / Brava 4 24-04-2005 08:28
(T) Main relay, the little white box thing? Cooter Cinquecento / Seicento 8 06-02-2005 00:41
(S) fiat brava bod boyin and lowering bravaboy Bravo / Brava 1 28-12-2003 20:39
Flasher relay Andrew Gronow Tipo 1 24-11-2003 17:21
