1st problem:
after changing wheels and changing the rusty oil sump (of motor oil), my gear lever has a stringy feeling. I mean, if no gear is engaged and you touch it a bit normally it wouldn't stay where you push it (as long as no gear is engaged) but it will come back in the middle. Unfortunately, this is no longer so. It will now just stay where you push it, that is if the motor is cold. It's also quite difficult to get the reverse gear in. After 0.5 mile, things become normal again so if you touch the gear lever then with no gear engaged it will resume its zero position by itself as it should.
What's happened here, any ideas? Is it somehow connected to the changing of the sump? This was done at the garage, so maybe they did fiddle with the gearbox in order to get the sump off?
2nd problem:
By the way, since I changed wheels the starting motor sometimes spins up without turning the motor. It never did this before. I don't now what I did to it, but when I changed front wheels I had to pull at the wheel nuts a lot so (to my surprise) the pull turned the wheel some 20 degrees outwards hm. Don't know if that is related to my first problem (see above).
Help, please? It's Fiat Bravo 1,4 SX 1995 55 kw
Zardo
1st problem:
2nd problem:
Zardo
