the ecu is matched to the red key, so it will start with the red key if the immobiliser is the problem (which seems very very likely).
but to get the blue key working again you need both the blue keys.
then its simply a matter of;
-insert the red key
-switch on igniton
-take red key out
-insert the first blue key
-switch on igniton
-take first blue key out
-insert the second blue key
-switch on igniton
-take second blue key out
-insert the red key
-switch on igniton
-take red key out
between taking one key out and putting the next in you have only a few seconds so be quick. it sometimes takes a few attempts.
then it will be back to normal.
if you cant find the red key, or you're missing one of the 2 blue keys, you wont be able to do this. in which case an ecu, lock set (1 ignition barrel, 2 doors, 1 boot, 1 petrol cap) and key set (1 red, 2 blue) is needed. that costs £100 at most places and fitting isnt hard at all.
fingers crossed it wont come to that and you'll have all 3 keys.
