I am ready to refit my cylinder head, on my 1.2 80sx, and a red warning sticker on the gasket set says always use new cylinder head bolts. This is quite common nowadays as they are often meant to stretch when fitting However the Haynes manual says you can refit the original ones. It also says that you should angle tighten the bolts twice, by 90deg. This last turn being the fourth stage in the tightening sequence. In my experience its odd to angle tighten more than once. Is this correct ? Does anyone know what the official Fiat workshop manual says ?
Martin
Martin
