Styling Front Components
Scarborough by the sea
I have notcied in the bravo that you cant really hear the front speakers that much, i am upgrading all of my stereo atm and am getting soem either JBL Power series components or Infinity Kappa Components, i was wondering is there a way to make them or has any1 made any modifications to the doors so you can hear the mid bass coming from the front doors, the tweeters would be easy enough to relocate to the dash somewhere,
Thanx
Phil
i've got jbl components up front and i found that the best way to get good sound from the mids in the doors is to use the correct speaker adapters so you get an airtight base for the speaker. the tweeters should be on the dash definately, the original fiat twerers are already there so you can replace them or leave the tweeters on show, its up to you. i hid the passive crossovers in the fusebox area, wiring it all up is far easier if you use the original speaker wire from the door speaker to the footwell, routing a new wire into the door would be difficult.
