Ok,
So some of you might know that ive got a problem with the bravo that the radiator fan doesnt turn on when it gets hot.
Now, I have taken the rad fan and assembly out completly for a better look and to understand exactly how it works.
First of all ou have the + and - to the fan motor itself. this is split to work via a relay and what I can only assume is the speed controller. Its a bigish round resistory looking thing.. ceramic feel to it and has started to crumble a bit anyway (suspect ).
Now, im assuming that the relay runs based on that a fan switch of some sort kicks (based on the temp of the coolant) and tells the relay it can now allow power through to the fan motor, which runs via the speed sensor.
and I correct?
The problem I actually have is that I cant find any sort of fan switch anywhere I have checked the fan motor and it runs and powers up when connecting it direct to the battery. ive checked the fuse which is fine. I have tried bypassing the speed sensor thing but to no avail as the fan switch hasnt been bypassed and so there is no current coming through anwyay.
so. where is the fan switch located on a 1.6 16v bravo with Aircon. It isnt on the radiator (or atleast ive failed to find it) and rather than pull the engine bay apart following wires, hopefully someone knows
Also, is it likely that the speed sensor could be faults as it has started to crumble slightly? Ide be able to work this out myself anyway if I could find the damn fan switch
thanks!
and I correct?
thanks!
