Hi Sammiboo,
Just had MOT on my Brava...Guess I wasn't as lucky...but there you go...
Mine failed on few things:
1) Failed on the Number Plates (character spacing too wide) would you believe ! Funny, they were on the car when I bougth it, so why it managed passed last year at the same MOT station !!! Did the law only changed this year ?
2) Failed on the rear brake led strip because a few of the leds were blown (only 5 of the 10 leds were working)...I took it apart and managed to fix them all ...but I wish I didn't...what a waste of time...wasted £10 for those leds and a whole afternoon...It worked fine, but I fear they'll blow again when the rain gets in...in the end I bought a complete new unit...guess the cost...37 pounds !!!!
3) Failed on the rear orange bulb...because it wasn't orange enough...fair enough. I think they do fade over time.
...now the biggy...
4) Failed on Exhaust manifold at the engine...apparently some bolt broke, so the exhaust was leaking. So needed a new gasket and new bolts... apparently when they took the old gasket out, they broke another couple of bolts which they had to drill out ... my heart sank when I heard this. Do you remember in your previous post to this that you mentioned some noise. Well, the loud "ticking" noise, which I thought was severe tappets or water pump, turned out to be coming from this exhaust leak.
Anyway, now that's all done, the baby is superbly quiet again. What a relief. Although I can just about hear the "common problem" tappets, but it is almost unnoticeable. I'm a lot happier now I know it is not big engine problem.
So all in all, it's not too bad an MOT, if ruling out item 4. Bit surprised at cost of item 2. Pity I did not have time to get used parts.
Next year might be expensive...the MOT advise were:
a) Brake hose pipes showing signs of cracks ... not sure why both of them as one of them was changed last year ... possibly the dodgy mechanic I used last year.
b) Brake pipes rusty ... probably get these done at the next opportunity ... don't like these types of comments ...
c) headlight dip pattern fading...so looking at new set of headlights.
Anyone with any ideas on costs on changing brake pipes & hoses ?
