The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 12-06-2006   #1
Trader Rating: (0)
Question bravo HGT complete brakes on 97 bravo 1.6 16v.
Hey guys (and gals...do they read stuff like this?? ) .... an hgt has just shown up in the local junkyard with excellent brakes and suspension and we were wondering if we can use everything on my brother's 1.6 16v (1997) ......sorry if the question has been asked ....I didn't really do an extensive search on the subject we are in a bit of a rush!!!!!....u see we need to tell junkyard if we want it or not since there's a bunch of guys interested also!
Can u just bolt-on the complete fronts (from hgt)??????
...and the whole rear setup even complete with the rear suspension will it also just bolt-on? He has drums now.
Anything alse he need to get from the hgt if all this is possible? Master cylinder from the etc???
He has to replace the front discs and pads because they are worn and also change his koni yellows for something more BUTT pleasing jejejeje so u see this is a great opportunity excellent brakes and 4 excellent bilsteins!!!!!!!
Thanks all in advance!
v61 ovarb taif is offline
Old 13-06-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: bravo HGT complete brakes on 97 bravo 1.6 16v.
i've had a good look at the HGT setup because i was considering the same thing when i had a 1.6. as far as i could tell the front and back suspension and brakes will change over fine. the front hubs look the same so you could probably get away with just removing the struts, calipers and discs and i expect they will fit on the 1.6 hubs no problem, i dont think you even need to change the brake pipes. the mounting points on the rear are in the same place so if you remove the full suspenison/brake setup it should bolt straight on, but the handbrake cable will be different, and im not sure the rear brake hoses would fit, to me it looked as though the best idea would be to remove the rear flexible brake hose with the rear calipers, and remove the handbrake cable. the 1.6 brake master cylinder should be fine, i cant see any advantage to removing the HGT one. remeber these brakes will be much easier to lock up under hard braking, and since the 1.6 doesnt have ABS it will depend on driver skill, especially in the wet. i once upgraded the brakes on a 1.3 escort and after the change it would lock all 4 whels with ease, not good when you slam the brakes on in an emergency, but good for taeching you how to control braking, if you live long enough to learn.
jug is offline
Old 13-06-2006   #3
Trader Rating: (0)
Hey Jug thanks for the info....my brother told the guys at the junkyard that he was going to keep the stuff so I know what this weekend is gonna look like for me! (darn grease sure is a pain to get off from under fingernails! ) wish us luck!
Old 14-06-2006   #4
jug
jug's Avatar
Trader Rating: (1)
good luck mate.
jug is offline
Old 24-06-2006   #5
Forum moderator
Helz's Avatar
Trader Rating: (3)
Helz has donated! United Kingdom
Let me know how you get on, if this is a relatively cheap and cheerful job it's something I'm interested in, rusty drums look awful and with the weight of the car I would like some firmer brakes behind it. An issue for me could be handbrake cable as the Bravo one may be different length to the Brava one, I'll have to check it out (unless someone knows off the top of their head).
Helz is offline
(G) How many bravo/as? sammiboo Bravo / Brava 255 28-02-2008 23:34
(G) How many Stilos activematt Stilo 755 12-11-2007 15:17
