The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 27-04-2006   #1
Site Sub Admin
sammiboo's Avatar
Trader Rating: (0)
sammiboo has donated! United Kingdom
exhaust fixed - but another problem
I thought this might cost a pretty penny. I took my car into ATS today cos my exhaust was making a right racket.
I guessed it was a bracket that had snapped. So told them what i thought it was when i took it in.
Turns out it was a bracket and they fixed it there and then gratis They also said my exhaust was in good condition so wouldnt need changing for a while.
There has been a clicky noise coming from the front end, i knew about this and was going to get it sorted when my car went for a cambelt change and service next month. They said they think it might be the water pump thats making that noise?!
Does that sound about right, it is getting a bit louder now, but I dont know if its safe to leave it till i get the cambelt and service.
RIP Coupe Former owner of 94 punto 55s, 96 bravo 1.6 sx (RIP) & 96 bravo 1.6sx Currently drives 98 bravo 1.6sx.
Had use of 97 fiat coupe 20vt and drives His 2006 Panda sporting multijet
Shop question? Order question see this thread Other than that - PM me
sammiboo is offline
Old 27-04-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: exhaust fixed - but another problem
a "clicky noise" can be the water pump, but just as easily the oil pump, or a worn tappet, or less likely but also possible is worn bearings in anything with a moving pulley, a loose or damaged ht lead which clicks when it sparks, electrical components such as injectors can click, relays can too.
i guess it does it when the car is both stationary and moving, and the clicking increases in speed as the engine revs rise? if thats the case its usually oil or water pump or tappet.
to decide which one you should stick a piece of hose pipe in your ear and then point the other end as close to the water pump as you can, then as close to the oil pump, then as close to the tappets, see where the click is loudest.
i'd hope for water pump becuase thats cheap and easy if you're getting the timing belt done, oil pump isnt a major job, neither is a tappet, so dont let it worry you. however if its getting worse you may be nearing the point of failure. if the oil or water pump failed it wont take long for the engine to overheat. i'd be keeping a close eye on my temp gauge just in case.
jug is offline
Old 07-06-2006   #3
My Marea has 1 big bootie
b1gduk's Avatar
Trader Rating: (0)
b1gduk has donated! United Kingdom
I love a happy ending, trouble is, the is no ending.
What happened ?
Dwayne Dibbley
b1gduk is offline
Old 07-06-2006   #4
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Binki
dave is offline
(T) Turbo exhaust design theory by Garrett. J333EVO Cinquecento / Seicento 28 08-11-2005 00:55
(T) electrical problem! a big one! pimped_HGT Bravo / Brava 0 03-11-2004 13:34
Advice sought for running repair on Panda Selecta exhaust barney_mcgrew Panda (Classic) 6 30-09-2004 10:22
(S) Sports Exhaust trim Roberto Bravo / Brava 11 24-09-2003 20:35
(T) Injector light / exhaust problem cmjt Bravo / Brava 0 15-04-2002 18:27
