Does my car have one also? I have a 99 Brava 100SX 1.6 16V manual and my driver's side is on the left.JoskeJTD said:If it has one it'll be infront of the drivers side rear wheel under a plastic cover.
Joske
Joske
How do I know if my car is like yours Helz, exactly where do I check to find out. If my car has one I really need to change it ASAP cos the fuel here is very crappy!!!Helz said:While we're on the topic, my fuel filter is built into the fuel tank so it's a whole tank replacement jobbie if/ when it needs done. Is there any way of checking it and if not, how often do Fiat recommend it is all replaced?
My car is fuel (petrol) version not diesel.....Helz said:I imagine if you have one it will be in the same place as the others above. I just read it in Haynes manual but this doesn't cover diesel versions so can't be of more help I'm afraid.
TheCROW said:My car is fuel (petrol) version not diesel.....
And if it has one exactly where do I look for it and exactly what does the plastic cover look like? Cos I didn't quite understand the previous post.
And one more thing, in my car the driver's side is on the left.
Thanx.
1242 Sorry Crow, I misread your post above, for some reason thought you said JTDJoskeJTD said:@ Helz
What engine do you have in your Brava?
Joske
Thankyou guys, I'll check it and get back to you.Helz said:1242 Sorry Crow, I misread your post above, for some reason thought you said JTD
I hope the other engine not having a fuel filter is not mine cos I don't know where to look for it.Helz said:I think the 1242 and one other engine size mentioned by Haynes (which I can't remember off the top of my head) are the only ones not to have inline filters; if it did, I am sure mine would have been changed at least once in the 46k it's done so far but that's never been done. Will double check though - or any other 1242 owners confirm or deny?
