Thread Tools
Old 29-07-2017   #1
Netherlands
TD100SX Start issues
Hi all,
My Bravo has some issues while starting the engine. The indicator for glow plugs is blinking, and turns off a few seconds after turning the key (before starting the engine). I have new glow plugs, but not installed yet.
However, when I turn the key to make contact, I hear something ticking like some sparks are jumping around from end to end (like on a stove). It appears it comes from behind the dashboard against the firewall. Also the engine will crank, but not start. The battery and dynamo are clearly not the issue.
Are the glow plugs the issue? Or has it something to do with contacts or fuses?
Looking forward to your respones!
Alico64 is offline Reply With Quote Quote
Old 29-07-2017   #2
Finland
Re: TD100SX Start issues
Hot air gun to the intake and try starting.
If it starts, it's most likely the plugs.
Neverth is offline Reply With Quote Quote
Old 29-07-2017   #3
Netherlands
I haven't tried that yet, but since I had the glow plugs on the shelf, I decided to replace the first one (and only one who can be reached the easiest). Turned out to be the main problem. Now I need to figure out how to reach the other three.
Also I noticed the air intake was loose on a couple of spots. Same goes for the Marea, is this a common problem with these older Fiats?
Good news is that the engine will start, so I'm able to drive to work again in the Bravo.
Issue has not been resolved completely, but at least I can go on from here.
Likes franglais liked this post
Old 29-07-2017   #4
France
Quote Originally Posted by Neverth View Post
Either that or a blast of start pilot or any other butane/ethanol start assistance spray, i would prefer that to the risk of melting a plastic part.
Marea Weekend 2002 Saint Moritz JTD 110 The thread
Marea Weekend 1999 ELX TD100 (DECEASED head gasket failure)
franglais is offline Reply With Quote Quote
Thread Tools
(T) 2011 500c semi auto, electronic issues, hill start, esp, stop start transmission etc. chris red 500 9 18-04-2016 16:00
(T) Nearly new, revving issues, stop start issues. bplanky500 500 9 15-06-2014 13:26
(T) Bravo Td100sx van without power Touro Bravo Bravo / Brava 7 19-02-2007 00:12
Bravo TD100SX Voodoo FIAT Boo Archives 19 15-08-2005 16:24
Bravo (Classic) My Bravo TD100SX Bravo_voodoo Members Motors 4 11-08-2005 21:07
