Thread Tools
Old 31-05-2017   #1
Poland
Unhappy Bravo 1.6 16V CF3 - too low idle rmp at ECU
Hello everyone, on start, i would like to sorry for my english
i've got problem with my Bravo 1.6 16V CF3 from 2001 year, mostly since i bought it two years ago. In this time, i've changed cambelt with all neccesery elements, then check is it correct twice, with original locks, spark plugs and ignition cables to NGK, Coil old was Champion, new is Valeo, camshaft sensor MM and many other parts, to fix problems with power or stable drive (car was jumping when accelerating). Injectors were at cleaning, all got 16 ohms at 20 degrees. I've got second ECU, because we though that it could be broken, like in stillo 1.6 and making some strange problems.
For now, i've got two problems, and no idea, where to look solution, because everything look good.
1. When it warm up to 80 degree of Celsius, idle rpm go down to 700, and are stable. In FES expected idle speed is 700, so it isn't problem with idle speed actuator. I clean whole throttle body but it doesnt get any efect.
2. After replace camshaft sensor i reset autoadaptation and phonic wheel adaptation, all as it is described in FES. But, Bravo with broken camshaft sensor was starting like this:
type in YT "Bravo 1.6 16V długie odpalanie " (i cant add URL cuz dont have 5 posts )
and now, after replace is like this:
type in YT "Bravo 1.6 16v CF3 - problem z odpalaniem po wymianie CPW"
I replace sensor, because it had short circuit and gave +1.89 on body of ECU after ignition, and engine didnt start. When ECU was isolated from earth in car, engine work normal.
Today i made compression test, this is result:
type in YT: "Bravo 1.6 16v CF3 - test kompresji"
I can do static or dynamic test, if you tell me, what need to be logged.
I will be grateful for any advices
czareklca is offline Reply With Quote Quote
Old 09-06-2017   #2
Poland
Re: Bravo 1.6 16V CF3 - too low idle rmp at ECU
2 days ago, i've unscrew camshaft position sensor and change its angle. Now there is no more missfire on start, it just need more time to catch. After start, work normal on idle rmp. Problem is only after few hours stand. If i stop him just after first start, and try to run again, it will start in second.
Now it start like this:
It's better but still it take to long
Any idea, what could be wrong?
Old 09-06-2017   #3
Perhaps worth replacing Crankshaft sensor
If not expensive as you have already changed cam sensor.
jackwhoo is offline Reply With Quote Quote
Old 09-06-2017   #4
Poland
My mistake with translate :/
Of course i didn't touch camshaft sensor. In whole story, everywhere "camshaft" should be "crankshaft" (i can't edit anymore).
For sure that i dont use wrong name again, here is photo:
Old 09-06-2017   #5
yes that is crank shaft sensor.
I don't know how close it should be to the phonic wheel but you could find out and check
Old 09-06-2017   #6
Poland
It should be between 0.5 and 1.5 mm. For now i'v got 0.55mm, before angle change was 0.95mm
Old 22-06-2017   #7
Poland
I just finish checking my intake for any vaccum leak and didnt find anything.
When i test my vaccum on running engine i notice, that it is a little bit to low. Tester show reason of it, as "too late timing".
Anyone knows is it possible to correct timing, or it is full electronic controled, and reason of problem is physical damage of something?
This is how it looks on vaccum tester:
Old 22-06-2017   #8
Finland
I still dont get what is the problem.
The engine is taking too long to start?
Only the second engine didn't have cam sensor so it fires blind every revolution (might take almost one crank rotation before firing injectors and coils) until it starts.
The first gen and the CF3 have crank sensor so the ECU waits for signal (might take almost two crank rotations) so it knows if it is on compression or exhaust stroke (or if the cam sensor is broken)
Neverth is online now Reply With Quote Quote
Old 22-06-2017   #9
Poland
My major problem, is long first start. It is important, that only first start after few hours not using, taking so long. If i start it, after few secs turn off and start again, it will fire up, without even half crank rotation.
The other thing is, that it has a two weeks, when everytime, fire up like this:
It happen, after disassembly coil, and assembly it after heat up (dont ask why i did it )
In my opinion, it is the only normal way, to fire up engine. I'm not sure, that ECU need to find "zero" position on crankshaft, to syncho coils and injections. Most engine's have crank sensor (even my old polo 1.0 from 1995 year) and all starts normal.
Second problem, is idle rpm, which is at 700 rpm. Some time ago, i have found topic:
http://www.fiatforum.com/fiat-boo-ar...1-6-marea.html
Same engine, and also 700 rpm, so maybe it is correct, that on work temp (up then 80 degree of Celcius), ECU is lowing idle speed to 700, but engine start shaking on this speed. RMP are stable, 698-703, but this shaking making me nervous.
As u have saw (or not) on my movie in my last post, i check vaccum on hot and it's to low. Normal vaccum is about 600 mbar, in my it is about 540 mbar. This same show MAP sensor ~400 mbar pressure in intake mainfold, as i have found, it should be ~320 mbar.
At all, Brafko is driving very good, accelerating (only sometimes a little jump when i press throtlle to strong). I feel, that it should have a little more power as for 103 KM and be more agressive when i accelerate on higher rpm (it looks like it have to think a sec before start speed up)
Old 23-06-2017   #10
Finland
There is crank sensor, but the engine needs to find the gap in the sensorring on the cranksaft to determine the angle in relation to the piston movement.
The second engine injects fuel and sparks every rotation even if it is on exhaust stroke. Once a cylinder fires, the crank acceleration is used to determine which stroke the engine is on.
The first engine and third (CF3) use the camshaft sensor to determine the stroke and do not inject fuel on the exhaust stroke when starting up.
If haynes states that the idle should be 800 +- 30, that is wrong.
The CF3 is completely different engine: 1596cc (78,4mm stroke) where the old ones are 1581cc (67,4mm stroke) with just different electronics.
Even the fiat manual states the idle to be 700 +-50 rpm (ignition advance of 4 degrees).
The CF3 is not that great as making the stroke longer seems to have caused more load on the pistons and atleast in Stilo they start to consume oil as they get older.
As for the shaking, depends on how much. My 1.6 shakes a lot if under load and under 1500rpm, but that is normal. As for shake on idle, I can feel the car vibrate, but it has always done it (last 9 years) so I don't really care.
Thanks jackwhoo thanked for this post
Likes jackwhoo liked this post
Old 23-06-2017   #11
Poland
Which fiat manual, states the idle to be 700 +-50 rpm??
Old 23-06-2017   #12
If the ECU is requesting an idle speed of 700 rpm then that's what fiat programmed the idle rpm to be.
No one knows how shaky your engine is at idle when at normal operation temperature.
Why not post a video? then you may get some helpful responses.
Old 23-06-2017   #13
Poland
Quote Originally Posted by jackwhoo View Post
If the ECU is requesting an idle speed of 700 rpm then that's what fiat programmed the idle rpm to be..
The problem is that in all books i've found, for 1596 ccm bravo, idle speed was 800 +- 50 rpm. Now, Neverth wrote, that he saw one with 700 rpm idle speed for CF3.
i'm not sure, does phone would be able to record it, but i will try.
Old 23-06-2017   #14
If ECU requests 700rpm that is what Fiat programmed engine speed to idle to be.
Old 23-06-2017   #15
Finland
Quote Originally Posted by czareklca View Post
Marea workshop manual, Vol4, Intro & Tech data page 50.
1.2 is specified at 820 +-50 rpm
Likes czareklca, jackwhoo liked this post
Thread Tools
(G) M3 (CF3) and M2 (CF3 (OPT 229)) engine version on punto 188 l0rd Punto (Mk2/2b) 0 20-03-2013 14:38
(T) Bravo with Low Idle Tony123 Bravo 12 13-11-2012 13:21
Multipla 1.6 16v 2001 plate low mpg and rough idle 5APPH1R5 Members Motors 5 24-09-2012 20:27
(T) 1.2 16V low idle novatron1_2 Stilo 5 28-07-2010 13:10
Bravo hesitates in low revs and stalls when idle Bea FIAT Boo Archives 7 29-09-2004 08:17
