FIAT Auto Specialist Team
Thread Tools
Old 23-06-2017   #16
Poland
Re: Bravo 1.6 16V CF3 - too low idle rmp at ECU
Neverth you're the man i double check "bravo/brava workshop manual" and im sure, that i saw 800+-50 for 1596 ccm. Maybe somewhen i look for it once more time
jackwhoo here You have:
This is how it start on hot engine. The funny think is, that vibrations come with door closing. Look at airbag after close door (time: 2:08). Before i have close the door, i didnt feel any vibration on wheel
czareklca is offline Reply With Quote Quote
Old 23-06-2017   #17
Sorry I can't see the vibration on video.
Perhaps a video of engine ?
jackwhoo is offline Reply With Quote Quote
Old 23-06-2017   #18
Poland
jackwhoo i'm trying to find something to record it without any stabilization. Or it was bad idea, to glue phone to airbag i will try better next time.
Old 23-06-2017   #19
Poland
Neverth i just remember, that in winter, when outside was -10 and lower, engine starts everytime like now on warmed up. There was no mather, does it stand 8 hours or 8 days, first start was like this:
When temp out was going up, problem with long start back.
It suggest that there is a problem with colant temp sensor or intake temp sensor, but i've checked both few times. What do You think about it?
Old 23-06-2017   #20
Finland
Vibration on steering wheel is normal, the engine mounts are over 15 years old so the rubber is not what it was when new.
As for coolant sensor, there should be two, one for the dash gauge and one for the ECU (not sure if on same housing, depends on the engine). To test if they cause the problem, just unplug them.
Same for intake air temperature.
Likes jackwhoo liked this post
Neverth is offline Reply With Quote Quote
Old 24-06-2017   #21
The vibration could very well be normal for your engine and car.
Possibly Fiat reduced idle speed to 700rpm to reduce emissions during tests at expense of smoothness.
If car starts (even if two or three cranks longer than you would prefer) drives correctly and doesn't use more fuel than it should , that is good.
Possibly you are thinking about it too much.
Old 24-06-2017   #22
Poland
Neverth, if i disconnect coolant temp sensor, nothing change, except error on ecu and nothing on desk (one sensor for ecu and dashboard). intake is integrated in MAP sensor, and if i disconnect it, engine stops.
jackwhoo maybe you are right
Thanks jackwhoo thanked for this post
Old 24-06-2017   #23
France
"if it ain't broke, don't f***ing fix it"
AvE
Likes czareklca, jackwhoo liked this post
Marea Weekend 2002 Saint Moritz JTD 110 The thread
Marea Weekend 1999 ELX TD100 (DECEASED head gasket failure)
franglais is offline Reply With Quote Quote
Old 12-07-2017   #24
Poland
https://soundcloud.com/eturbo-helpde...od-obciazeniem
Listen from 0:22, when i put throttle to full, i hear some strange noises
Thread Tools
(G) M3 (CF3) and M2 (CF3 (OPT 229)) engine version on punto 188 l0rd Punto (Mk2/2b) 0 20-03-2013 14:38
(T) Bravo with Low Idle Tony123 Bravo 12 13-11-2012 13:21
Multipla 1.6 16v 2001 plate low mpg and rough idle 5APPH1R5 Members Motors 5 24-09-2012 20:27
(T) 1.2 16V low idle novatron1_2 Stilo 5 28-07-2010 13:10
Bravo hesitates in low revs and stalls when idle Bea FIAT Boo Archives 7 29-09-2004 08:17
