Lamps by Post - For all your lighting needs
Thread Tools
Old 19-05-2017   #1
Romania
1.9 jtd slow rev
So i had a problem whith the turbo for about 1 month and yesterday i solve the problem.the car was working great
,but today the injector light come on the dash and the car didnt want to accelerate more than 3400 rev.i tried an ecu restart and after than the car worked for 30 min the injector light was gone this half hour and after that boom the light apears again and the dint rev above 3400 again.if someone knows whats the problem please help me whith some tips.thanks
motomete2004 is offline Reply With Quote Quote
Old 19-05-2017   #2
varesecrazy has donated!
Re: 1.9 jtd slow rev
Quote Originally Posted by motomete2004 View Post
so - how did you fix the turbo..??
Old 19-05-2017   #3
Romania
The needed a cleaning he had some dirt in some canals on the ax.
Old 19-05-2017   #4
Try removing and cleaning the EGR - Exhaust Gas Recycler.
A different car, I know, but my wife's 2.2 diesel Saab had the same symptoms as you describe. It was also sluggish and threw out clouds of black smoke when trying to accelerate.
I removed the EGR - it was full of thick, black oily carbon. Once cleaned out and refitted, the car drove ok.
Here's a Youtube link about cleaning EGRs (not your particular engine .. but the principle is the same):
https://www.youtube.com/results?sear...leaning+an+egr
glenn2602 is offline Reply With Quote Quote
Old 20-05-2017   #5
Romania
I have mechanic EGR and is blocked for 2 years i have cancel it.is not from there for sure
Old 20-05-2017   #6
you need to connect computer to car to tell why warning light on
or you will go crazy trying to guess
jackwhoo is offline Reply With Quote Quote
Old 20-05-2017   #7
Romania
Try that but no errors apears on the ecu scan
Old 20-05-2017   #8
If the fault light is on there is a stored code , you need to find a code reader that will work with your car.
Old 23-05-2017   #9
Romania
So yesterday i change the map senzor because it was an error and today the car still not working and i have this errors.maybe someone knows whats the problem.i think maybe a turbo pipe is broken or the intercooler its cracked i dont know.
Old 23-05-2017   #10
Look up the meaning of the fault codes shown on your scan.
Use Google
Old 23-05-2017   #11
Romania
I have change the intercooler and the error is gone.the car is working good but now i think the maf senzor is gone because a friend who is a mechanic take the car for a spin and he said that still he has a lack of power and we take out the maf jack and the car has a little bit more power.if the maf senzor is broken i can see that on an ecu scan?
Old 23-05-2017   #12
You must look at ECU scan you have already done look up codes so you understand what they mean.
Show scan to your mechanic friend.
Then erase codes.
Then drive car for a few days.
Then scan for codes again and take action to fix codes.
You can ignore the code relating to glow plugs that is only for starting.
Old 24-05-2017   #13
Romania
Does anybody know where to look for the code of this pipe i cant find it.
Old 24-05-2017   #14
Romania
So i think i have find the problem.last night the car wa working great.today in morning in my way to work the light again apears and the was slow.i started to think what i did yesterday.i ask a friend to help me to push the acceleration and i go under the car to check the pipes.after a few pedals my friend told me the check light is gone i was like whattt???i take tge car for a spin and work great.but whithout the pipes that the turbo takes air from outside i have put a picture.and the pipe that i uploaded early is broken.so i think the turbo takes air from outside before the maf senzor and agai from that broken pipe.i started to think logic if the pipe is broken before the maf senzor is not working good the values are low.
Old 24-05-2017   #15
Romania
This is the part that goes in to the filter
Thread Tools
(T) When I rev Car, revs come down slow david295 Punto (Mk2/2b) 12 26-04-2017 20:24
(T) Diesel panda very slow to rev up Breedy Panda 2 10-10-2011 10:41
(T) JTD - very slow acceleration kayaker-ant Stilo 7 30-01-2010 00:26
(G) My JTD seems slow? Oakley28 Stilo 18 12-08-2009 20:21
(G) Slow JTD Brava Hellcat Bravo / Brava 1 30-05-2006 23:13
