Thread Tools
Old 14-04-2017   #1
Best way to relieve fuel pressure
Hi - this weekend am going to replace a dead injector on Brava 1.6 W Reg.
I was wondering what best way to relieve fuel pressure is? Car has not been driven for 48hrs. Being a late model it has the pressure relief valve at end of fuel rail - is holding a towel over this whilst pressing in valve enough to contain spill?
The other option is to disconnect the quick fit connector on pipe on bulkhead at back of engine - could I also put tray under this and use towel here instead?
Thanks for any advice
Ted
TedR is offline Reply With Quote Quote
Old 14-04-2017   #2
varesecrazy has donated!
Re: Best way to relieve fuel pressure
Quote Originally Posted by TedR View Post
Ted
lift rear seat.. remove 3 x phillips crews, (access info - http://www.fiatforum.com/punto-mk1-g...o-1-1-spi.html )
disconnect wiring to fuel pump
run engine until it runs out of fuel..
reconnect when you are done.. system is self priming
Old 15-04-2017   #3
Thanks I'll give that a try!
Ted
Old 19-04-2017   #4
Ted
Most cars have a fuel pump relay that can be disabled by unplugging a fuse.
Do this then fire up the motor until it cuts out.
There is also a trip switch incase of an accident that cuts off the fuel pump, most cars have this in the passenger foot well under the carpet (usually near the door on the side of the chassis inside the foot well)... you can inhibit this (same as pulling fuse to the relay as above).
Likes Mamdouh, varesecrazy liked this post
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is offline Reply With Quote Quote
Thread Tools
(T) fuel pressure bandette10 124 Spider (Classic) 2 15-11-2016 19:12
Strada No fuel pressure LHuman Newbie Central 1 16-06-2016 16:50
(T) Fuel pressure 1.2? Olliver 500 2 19-02-2015 22:15
(G) fuel pressure!! jonesygpm Punto (Mk2/2b) 2 04-02-2007 13:25
Relieve daily stresses with............ Liam Leisure Lounge 2 06-04-2005 13:35
