Thread Tools
Old 26-03-2017   #1
Lithuania
Brava no spark (1996 1.6)
Hello Friends,
I got new problem with my Brava. There are no spark, so I am not able to start the car. There are no problem with ignition coil, problem is elsewhere.
One strange thing, what happened together: when I turn on the ignition, main cooler fan starting to rotate at full speed and stops when I turn of the ignition (car is absolutely cold). I am not sure, that both problems are relative, but it happened in same time.
Where can be a problem? Something with ECU. I tried to connect laptop to 3pin connector, but with no luck (no response from ECU). I have other Brava (1997 1.4) and can connect to its ECU with no problems.
And second question: does main fan working only with ignition on Brava 1996 1.6? When my other Brava heating, it working with or without ignition.
Thank You
Soldier is offline Reply With Quote Quote
Old 28-03-2017   #2
Sri Lanka
Re: Brava no spark (1996 1.6)
check the battery, starter motor, fuel lines maybe? Fan operating on ignition can be due to a wrong signal sent by the ecu, or your themo malfunctioning or a wiring issue.
gihan798114 is offline Reply With Quote Quote
Old 08-08-2017   #3
Egypt
Unplug the ECU and clean the pins with dry cleaner spray..
Starter motor need a check, if you can run the car by pushing it or sliding it,then starter motor is the problem..
Last if ecu cleaning affect nothing,you need to inspect fan relays.
Mamdouh is offline Reply With Quote Quote
Old 08-08-2017   #4
varesecrazy has donated!
@Soldier
This thread is 5 months old...
Thread Tools
(T) 1996 fiat punto-no spark! badmechanic Punto (Mk1) 3 05-05-2005 08:51
