B bsjtdgt New member Joined Oct 7, 2014 Messages 11 Points 3 Jan 18, 2017 #1 Hi everibody i need help on the mesurements for the batterie to a 1.9 jtd 105hp with ac sistem, i know its 12v and more than 600ah but i dont know whats the max with and hight that suites the compartement just fine.
OP OP B bsjtdgt New member Joined Oct 7, 2014 Messages 11 Points 3 Jan 18, 2017 #2 Help ? No one has mesure what batterie you got.
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,975 Points 7,834 Location Near the M4 Jan 18, 2017 #3 bsjtdgt said: Help ? No one has mesure what batterie you got. Click to expand... Ill measure my marea jtd with ac EDIT - has a 075 battery 570 amps 9.5" long x 7" wide x 7" tall 240 x 180 x 180 mm ALMOST fills the tray.. may be able to go another cm on width , 2 cm on length , not sure about height Charlie Last edited: Jan 18, 2017
OP OP B bsjtdgt New member Joined Oct 7, 2014 Messages 11 Points 3 Jan 18, 2017 #4 Thank's a lot mate i'll go right away buy a new one, just to be sure its got nothing to do with the lumpy idle problem i'm getting
