Thread Tools
Old 19-02-2017   #31
Dameincollings has donated!
Re: fiat bravo hgt turbo
Has anyone had issues with trying to locate the ecu? Sames like the coupes loom is longer and now struggling to find a home for the ecu! Help will be appreciated!
Dameincollings is offline Reply With Quote Quote
Old 19-03-2017   #32
Evening all, I'm now under going to plum in my oil pressure gauge and temperature gauge only problem is, is where to tap off from! Can I tap off the hex bolts on the oil filter housing?
Old 19-03-2017   #33
picture of the oil housing
Old 19-03-2017   #34
justin6430 has donated!
You don't need to tap into anything like that. What gauges are you using? Does your sump have a temperature sensor on it? Both gauges can be wired electrically.
justin6430 is offline Reply With Quote Quote
Old 19-03-2017   #35
oh I see! I've never installed oil pressure and temperature gauges before! I have autogauge gauges. There is a sensor on the sump but what it is I'm unaware.
ID:	178580   Click image for larger version
Old 19-03-2017   #36
So if you are lucky, your oil temperature gauge sensor will screw into your sump to replace the original one I spoke about. The sender unit for the oil pressure should also replace the original. No plumbing required.....
Old 19-03-2017   #37
Ok that's great! Do you know where the original oil pressure sender is located?
Old 19-03-2017   #38
It's at the back of the engine.
Likes Dameincollings liked this post
Old 20-03-2017   #39
Finland
Those look like 1/4 NTP, the oil pressure switch has bigger thread so you'd need an adapter.
The oil pressure gauge on my marea is on a 1/2 BSP plug with thread tapped into it (T-piece on oil line on filter relocation to the gearbox with bigger filter)
Neverth is offline Reply With Quote Quote
Old 07-06-2017   #40
Hi all, I'm in search of a passenger airbag panel! Anyone have one of these kicking around?
Old 08-07-2017   #41
Any advice on where a can fill the gearbox oil? I've checked out fccuk and they say to fill the gearbox through the gearbox dipstick! Unfortunately the dipstick fouled with my steering rack pipe work! So I blanked it off! Is there anywhere else I can fill the oil?
Old 08-07-2017   #42
Also an update, I've got a hybrid Turbo built by FC performance, front mount installed and a SIP from pro alloy fitted. Coming together quite nicely now.
ID:	182156   Click image for larger version
ID:	182158   Click image for larger version
Thanks CFREITAS thanked for this post
Likes justin6430, CFREITAS liked this post
Old 08-07-2017   #43
CFREITAS has donated!
Looking good buddy
Bravo HGT 155 20v
Bravo HGTT 20v TURBO
CFREITAS is offline Reply With Quote Quote
Old 08-07-2017   #44
any advice on filling the gearbox oil?
Old 12-07-2017   #45
varesecrazy has donated!
Depends on how you blanked it off..
Whats the level plug situation..?
Thread Tools
FIAT BRAVO HGT TURBO... !!! DrSergioDJ FIAT Boo Archives 14 26-05-2003 22:37
Fiat Bravo HGT Turbo Juan FIAT Boo Archives 7 10-09-2001 21:39
