Technical bravo mk1 lambda sensor
Sri Lanka
Hi all,
I just want to know if the following lambda sensors will match with the fiat bravo mk1 1.4.
my car is doing like 5km/1l :mad: ..half a tank will do like 100km, thats like 25l of petrol :bang::bang::bang:
there is no leak in exhaust, no issue with spark plugs, air filter is good and clean. As the bravo comes with electronic carburetor, no one is willing to put their hands on the carb :bang::bang:
so my last resort will be the oxygen/lambda sensor. and these are the ones i could find from ebay
ebay 1
ebay 2
are they upto the correct specs of mk1? or do i need to look for something in the car also :)
regards
you mentioned previously in another thread, that you had removed the thermostat, if you have not yet replaced this, i would make that a priority along with making sure that the temperature sensor is relaying the correct values to the ECU. A reduced coolant temperature (real or erroneous) will cause the fuel ration to be constantly rich, increasing your fuel consuption.
yes i know i haev posted this issue, i want to know the other possibilities also that why i asked :) will replace the thermostat soon, already gave priority :eek:
