Hi all my engine start made ticking noise its not there all the time i upload some video on YouTube if any one can tel me what its the problem thanks
If you did an oil change then you should have changed the filter because this holds quite a lot of old oil as well as trapped muck and sediments. When you have serviced the oil pipes (and stopped the noise) then add some engine flush and drain the oil again, start with everything clean.
As I said before, an older spec oil for Diesel engines will clean the engine better because of the extra detergents.
