Dear fellow Fiat drivers.
I have a Fiat Bravo 1.4 from 1997.
Everything is working fine on the car, but recently it has developed a braking issue, which is NOT constant!
When I drive along, and everything is fine with the brakes, then suddenly a metallic tin sound can be heard, it sounds like it is coming from behind the firewall down by my left foot. The sound is like a small tin fan hitting another piece of metal, and when I try to brake, the pedal shudders, like you would expect when pressing the braking pedal all the way down and the ABS system will kick in. But I am not able to fully compress the pedal, when I hear that noise. Then as sudden as the weird tin sound startet, it stops, and I am then able to brake perfectly normal again.
I do not get any warnings (ABS or tracking control) on my dashboard.
Has anyone experienced something similar/same? And are the any obvious faults?
Best regards
Viking1
Best regards
Viking1
