The ELM 327 interface is "smart" and decodes the data on bus into numbers / text. This means it only works with standarised protocols, regardless of the software used. The VAG-COM interface is "dumb" and just changes the the voltage levels to suit the computer. This menas the software can work with non-standard protocols like the early airbag system. The VAG-COM does not support CAN so is of limited use on newer vehicles.
Robert G8RPI.
Thank you very much! That makes sense. That is why is works with other vehicles, just need the correct software. :idea::worship:
