Picked up the Brava recently for a cheap run about to work. Only fueled it twice so not too bad on fuel at all. However fuelling for the second time today was quite the disaster. The punp either clicked out of it completely spat out of the tank. Tried various angles with the nozzle to no avail. Used to just pushing it in to the hilt and then fueling.
Eventually I was able to hold it half way and fuel until the top part of the opening filled, drained into the tank in a second then repeated. 5 mins to do £30 though, not right.
There is a green plastic insert in the tube leading to the tank. I am assuming this is playing some part in all of this? Im not particularly knowledgeable about cars, but don't want to be forking out for a mechanic if I can fix it myself.
Please let me know what you think the issue might be?
cheers
cheers
