Hi chaps!
I'm new to the forum - a long-term Fiat driver, having got through 2 Unos and a Tipo TD (looking out for another: they're fabulous) and currently on a Brava 1.4 SX. Which is causing problems...
In a nutshell, I noticed a couple of times lately that the temperature was rising to around 110 degrees before the thermostat kicked in and heating system worked as usual. Then, the other day, the temperature just kept rising until it was nearly on the red - no worries, I thought, the thermostat's jiggered.
I replaced the thermostat this afternoon, but the problem's still there. The water in the radiator is cold and pours out of the top when you take the cap off, which made me concerned for a cylinder head gasket, but there's no water in the oil and the engine's running fine.
Spoke to my mechanic, and he reckoned it could be an air lock - this could be the problem, as there's no hot air coming out of the heater. How would I fix it? And what else could the problem be?
Was going to add some questions on fuel economy, but reading through some earlier posts has answered that question...
By the way, I would be driving my girlfriend's Cinq Sporting today if it hadn't had a disagreement with a Landrover Discovery on Monday (http://www.fotolog.net/kit_allen/?pid=10019033) This hurt a lot!
Cheers, Trumpet
Cheers, Trumpet
