mainbataineh
- Sep 12, 2005
- 1
- 1
I have a fiat bravo 1997 1.4 litre 12 valve car.
I have two main problems:
1) The fuel consumption is extremely high; when i first start the car raw gas comes out of the exhaust, i can smell a very strong gas odor mostly when it first starts, and it goes on even after it is warmed up, but with less intensity.
2) I have a problem with its acceleration especially when it is fully warmed up. When i press the gas pedal, there is a delay and then after that it seems that it will accelerate then another delay, then eventually slow acceleration happens. the delay becomes longer the more i press the pedal down.
I have tried almost everything, I paid all my money to fix this problem but nothing happened. I replaced the oxygen sensor, the air filter, the fuel filter, the timing belt, the spark plugs along with their cables, the exhaust system. I cleaned the injector using ultrasound at its company, and replaced its cascades. The ECU doesn't show any errors in its memory, everything seems normal. but nothing changed...
I am in desperate need for help. Thank you in advance...
