Hi All,
I am seeking for your help once again. Looks like the problem on my '97 Fiat Brava 1.4sx has come back to haunt me after a year !
A couple of weeks back, I was driving home one rainy day, the car just came to a stop at the side of the street. Tried to restart it, the engine tries but it did not want to crank (turn over). The next day, it restarted again until, yesterday, it was raining heavily and thundering again. I drove my car home ok until I just came to stop at home and reversed park. Then the engine just came to a stop. I tried to re-start it, and the engine tries, but just does not want crank. I hear a little "thump" noise every so often which sounds like one of the spark plugs is not firing.
Today, I took out the plugs leads and notice 3 of them were wet. The only one which was dry was the one at the drivers side. Looks like some water got into those 3 spark plug holes somehow. I can't really understand how water can get into there, as everywhere around it appear dry (including the plug leads). I also checked the oil cap and oil dip stick, and there is no sign of any mayo-type substances, so it does not appear like a blown head gasket. It does not appear like I am loosing coolant fluid either. There is no indication of any problem on the dash instrument panel.
When I had the problem a year back, I could only put it down to condensation and damp as once I got it started then, it has never given me any problems until now. At that time, the car failed to start on a Monday morning after I gave the car a wash on a Saturday and left it standing over a weekend without driving it (maybe just a coincident).
I tried changing the spark plugs today, and it is still the same problem.
The only major thing done to the car is cambelt & drive belt change in March, but as it has been running fine since the change, I can't see why that would be a problem (unless it snapped). Apart from that, just normal general maintenance: oil change every 6K, brake pads, etc..
Anyone with any fixes on these types of starting problems (even common known problems in this area) how I could go about checking what may be wrong before taking it to a garage ?
Is condensation a common problem with this model ? My friend mentioned perhaps "dizzy" maybe damp - is this a possibility ?
I am not sure if changing the plug leads back to the originals on the car will show any different (they were replaced a year ago with new "Bosch silicone"-types and haven't given me any probs).
If it really a condensation issue, looks like I will need a really good blow dryer to fry the plugs, plug leads and holes out.
Your advice greatly appreciated...
Chuck
Chuck
