Technical Boot Not Closing
Gli Azzurri
Good Afternoon Fiat fans.
I've had a 51 plate Brava (5 door) since last august, got it for a tidy 300 quid!
It popped a head gasket shortly afterwards, but oh well, still a bargain.
Now i have another problem, the boot doesn't seem to wanna close.
The gold bits are meeting, which means the boot light isn't on all the time, but the bottom hook doesn't seem to reach the top mechanism, so it can't be closed.
Any advice on this? so far my solution has been smash it with a hammer, trying to pry the bottom hook further up with pliers and taking out five screws from the surrounding plastic.
To be honest, i don't really know what i'm doing haha
Any help would be much appreciated.:worship:
1st- open boot,
use a screwdriver to make sure that the catch actually works properly ( swings through an arc then latches,
push release button,
do it again.. repeat a few times,
add lubricant if notchy..,
if all that works o.k.,
you should be able to slacken the mounting bolts of the lock assembly ( and the lower catch plate) and push them up as high as possible ( to meet),
nip-up hand tight,
GENTLY close boot - ..when this works o.k.,
lock up mounting bolts TIGHT,
Charlie
Are the mounting bolts the square plastic things either side of the mechanism?. I'll try it again in a bit and post pictures if i can't get it done.
You have to take some of the trim out to access the striker plate bolts, it has lots of movement when loose. I added a picture to show it;
I have had this for a while. I did most of what has been suggested here with no success. My simple solution---have a mate pull UP the boot release lever at the side of the drivers door. You then drop down the boot and voila !!! The problem is from the release cable I think. I have a "glue stick"wedged under it now permanently and it works a treat !!!:)
Aye could be. I wasnt prepared to try and strip the linkage all through the car to try and see for sure. So its the glue stick trick for a while at least!!:)
