Technical Problems with diagnosis of Brava 1.4
Bravavod
Hi everybody!
I have Brava 1.4SX 12V(1998).And also I have three lights on the dashboard-engine,ABS and,SRS :)
And I really need to understand,what is the problem with each of them,especially,with engine,because fuel consumption is about 14 letres per km and I don't like this:)
I have ordered from ebay VagKom and
3-pin adapter
To connect I tried to use few versions of FiatECUScan and MultiECUScan,with different drivers,under 32-bit Windows XP SP2 and Windows 8...but the answer is only one ...NO ECU RESPONSE.
Of course,I tried to connect to all three modules.
As I have understand, the purchased KKL adapter is compatible not only with VW,audi and seat(as it is marked in the ebay's advertisment), but with any car of VW concern.So,I think,that isn't a problem.
May be it is needed to rewire hookups?
Thank you.
Sorry,if there was such querstion at the forum already.
Hello Bravavod, I have exactly the same problem for which they once lent me an interface cable but did not work and I am looking into buying the OBD2 VAG 409 KKL USB Ecu Scan Diagnostic Interface With CD For Fiat , but still have some fear it wont work, I have a 1999 Brava 1.6 sx
