Zombiebiker600
- Mar 26, 2014
- 4
- 2
Warning!! Newbie alert!!
Hi one and all... I hope you can help with an issue or two that I have with my 2001 Bravo 100 SX.
Firstly my brake lights don't seem to be working at all. I have checked the bulbs on either side of the car and both are fine and the filaments haven't blown. I even looked at the fuse panel and cannot see a blown fuse although I'm not 100% which one is for the brake lights. No.12 or 13? I fear it's the brake switch at fault and wonder if it's easy to replace or at least check. Could there be another issue here at all?
Secondly... when I attempted to change the bulbs I then tried to start the car and it would not fire up anymore. The starter kicks in and turns the engine but it will not fire up. I fear it maybe a Key/Immobiliser related issue as the key dashboard light no longer lights when I turn the ignition on. I have also had problems trying to start the car before. I sometimes have to try numerous times before it starts and sometimes the key light stays on whilst driving. I also fear that because I only have the red key I may be somewhat screwed.
I hope you can help and advise me.
Many thanks in advance.
