Hi
fiat brava 1.4SX P reg.
Air bag light is on permanently.
Air bag ECU number 464793640
ECU PCB: Hitachi GE216450-A
Unfortunantly Ive fallen foul of the new MOT air bag rules and being a P reg no one seems to have the right connector to read the ECU.
However, I have discovered that the airbag ECU did have some slight water damage and have cleaned it up. Even more Unfortunately a couple of components have also been damaged. One resistor and one capacitor. I can read the resistors value but the capacitor value has erased.
On the of chance that someone has a ecu apart can you confirm what value C31 is.
The capacitor is on the underside, opposite side of the board to the connector. The value should be represented by a letter and numberon top of the device which is a small square chip with silvered ends.
Hoping that with these replaced I can get airbag working properly.
SR
SR
