Matthew230
- Jun 23, 2005
- 1
- 1
Hi
I have a 1.2 T reg Bravo. It is quite high mileage, and seems to run nicely at high speeds.
However it has started having problems when idling, the revs drop and the engine labors. And also when driving, when slowing for traffic lights or something it keeps stalling. I took it to a garage with this problem a while ago and they reset the ECU. This solved the problem for a while, then it re-occured and the garage reset the ECU again, which solved the problem for a shorter time.
I have heard about stepper motor problems, could this be the answer. I'm a bit relunctant to spend £200 on getting a new one fitted if the problem is just going to re-occur.
Does anyone know what else it could be, and also if there is somewhere I could find detailed instructions on changing the stepper motor if I wanted to do it myself. ???
Also does disconnecting the battery for a couple of hours reset the ECU ??
Matt
Matt
