Technical Radio Code
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
JZeus
While trying to solve this problem:
https://www.fiatforum.com/bravo-brava/312149-problem-dipped-beam.html?p=3118358
I pulled out some fuses to check they were OK - and one of them shut down the radio :bang: It now needs to have a code input to get it back working. So 2 questions:
1) How do you input the code? This is not as daft a question as it may seem - as due to damp the display is knackered...so I need to know the keys to push without being able to see what the display is telling me - for example, do you push the 4 number keys, and then a key to enter ( and what would that enter key be )?
2) I'm not sure what the code is for my stereo - where can I find it? Or can the dealers get me the info?
Thanks all
Thanks for getting back.
I think I found the code ( 1602 )
And I think I can enter it OK - it seems the number buttons activate the 4 digits needed.
So if I press button '1' - it will enter the first number of the code. As example - if I press it three times it will input '3' for the first number.
I then press the button '2' to enter the second digit and so on.
So I managed to enter all the numbers. Then nothing. The radio does NOT spring into life.
Do I have to press an additional button to ' enter ' the code
Hi
Not sure of the make - it's one of the built in ones.
Now - as I said above one of my problems is I have a duff display...it only shows part of the word / number on the LCD.
But there seems to be just enough showing to allow me to see what is up there. And as I said I think I can input the code.
However - I just noticed when I turn the stereo on a ( part ) word is displayed,
which looks like it says " SAFE ".
Does this mean anything....I would expect it to say " CODE "...someone suggested it may mean that it has to be left for 24 hours before you can try to input the code.
Any thoughts
cheers
If it's the standard Brava/o radio, you need to press the "TP" button for about 3 seconds after entering the code.
