Hi forum, I have a 57 plate Bravo & have a problem with the n/s rear door. You can open it from the inside with no problem, but if you try from the out side it will only open about 5% of the time. I taken the door panel off and everything seems intact, does anybody know if there is any way of adjusting anything or if a part is required what bit would I need to purchase. Any help would be much appreciated as the MOT is due in just over a months time. Cheers Mark
