I took the wifes 'new' 99 Brava to work today, very pleased with the engine etc and found it to be quite nippy.
The only things that it's missing are an arm rest for the driver and most importantly a cup holder for my travel mug.
Are either of these items available to buy/bodge/ or blag??
Had to do a few little jobs on it while at work, cleared out the drain holes for the windscreen, filled the washer bottle, fixed the leak I then discovered from a loose water pump, blew years worth of crud out of a windscreen washer jet and oiled up the doors. these ned neew handles and the drivers door needs the check strap bracket which I believe is a common problem.
Is it a big job to pull the lever back out of the door? I tried half heartedly but I wasnt going to strip the door down.
