ru55turn3r
- Aug 24, 2011
- 1
- 1
Hi there and thanks for looking at my post.
I have a Bravo HGT that my girlfriend has been using for the past few months. A couple of months ago we started experiencing an intermitant fault where we weren't able to select gears. You'd be driving normally, go to change gear and be unable to slide the lever and be stuck in neutral. After a couple of minutes or a few pumps of the clutch you could slip the lever in and continue.
Anyway, two days ago it came to a head and now it is not possible to select a gear at all unless the engine is switched off. If you select a gear and start the car with the clutch depressed it tries to drive. I have checked the brake fluid and it's full (after checking this forum out!), and i've geared myself up for a clutch replacement over bank holiday weekend, wasn't really my plan!
I was only interested in finding out whether this is a common fault or whether anyone has experienced anything similar? I found a few old posts referring to clutch spring failure that aren't dissimilar. Im pretty sure im neck deep in clutch fixing anyway.
any help will be much appreciated, thanks in advance!
