Styling Bravo Door handle(s)!
Dundee
Hallo!
Hi, all (y)
I'm new to the site, so just like to say hi(look up! :p ), and that im recently, the proud(!) owner of a 1.6SX Bravo, so will hopefully be on here to share my views/experiences with you all...quite often! :D
Till then,take care pplz! :cool:
Hi welcome, I have an old N reg 1.6, Had a bit of hassle with it, but ok for the moment. I will get round to Modding it soon. :D
welcome.
I'm guessing by your title you are having a little trouble with perishing door handles? It happens. The rubber handles corrode and split after time which leaves them looking a little tatty.
The solution is to fit handles from the Marea which can be painted in the same colour of your car and do not perish. A guide on how to do this can be found here http://www.bravo-guide.co.uk/mod-a-bravo.htm#handle
wimmy said:
welcome.
Hi there, just thought I'd tell you the 'budget' way of repair for the Bravo door handles! :D
We're selling my wife's 1.4SX, so didn't want to go through the time and cost of replacing the handles. :bang: Instead, I peeled off the rubber around the barrel portion of the handles (not the 'pull' part) and it looked quite good, so I carefully applied translucent silica gel (same stuff you use around the kitchen tops) all the way around the black plastic surrounding the barrel.
It actually looks very nice and forms a great seal, but I was worried about it coming away from the metal, so I cleaned the metal around the barrel plastic with alcohol (Isopropyl). There is some movement between the plastic and the door metal when you open the car door :eek: , but it is minimal, and the gel has held well. The overall result is that the lines of the door looks great, and the 'modification' doesn't look out of place! :p Only time will tell as to how long it'll last, but it is a repair that can be done over and over again, very cheaply.
By the way, I'm still a Fiat owner ;) ; Replacement car No2 is a Brava 115 ELX with all the trimmings!
