Joe_Pineapples
Hi folks
My brakes are rubbish. I've swapped the discs and pads over from a donor car, because the brakes were quite new on that one and they worked really well.
After the swap, the brakes are still better on the donor car than my new one :-(
I'm going to completely change the brake fluid, but do I have to drain / bleed the clutch as well - as I understand it, it uses the same reservoir? I don't think the system has air in it, because the brakes are consistent (consistently crap, that is) but maybe the fluid has been contaminated and I don't know how long its been in there.
Also, is there anything else that I should check that could be making the brakes rubbish?
The car is a Bravo 1.8HLX. The old one was a mk1 and the new one is a mk2.
