So you are saying it is ok to mix water or anti freeze with premix coolant?
MMMmmm ok.
All the internal vehicle manufacture memos we get from most of our franchises must be wrong as is the Renault owner handbook which also warns you not to mix with anything bar coolant (premix).
If you pay the price for a decent premix not a supermarket or halfrauds speacial cheap deal you will not get tap water mixed in it, you will get all the addatives your engine may require, which most concentrates don't give you.
But if you think there is no differance and you can top up premixed coolant with either water, distilled or not or antifreeze than thats fine by me, the age of the vehicle it is going in to it should at a guess not do a thing, damage wise. I ran mine on tap water and Saab anti freeze, most workshops you go to will top up with tap water around here even we do as a major vehicle outlet of 7 franchise, tap water for us on the older cars and some Suzkies, the rest is coolant to manufacturer standard.
I am guessing the chap with the R8, who had it flatbacked into us yesterday thought the same as you, during the cold spell before Christmas he throught his R8 was low on coolant so he topped up with halfrauds premium antifreeze (what ever that is), drove the car around 200miles home left it in his garage to find a puddle under it on boxingday and a very strange noise when it ran, he faces a bill of around a grand now, as water pump has gone and some gaskets are leaking badly, he wants warranty, Audi say no and send a sample of coolant as it sounds like he has added anti freeze to it, Audi have told us what is wrong with it and to change every gasket on the cooling system, other wise it WILL spring another leak, they even have an alkaline solution to flush system with, moral of story, its all in your handbook, you probally will get away with mixing concentrate with premix, with older cars, all you will do is screw up the premix and lessen it to a normal anti freeze, it you are using the real cheap stuff then this is probally all you have bought anyway........
As I said it is like oil some people run thier cars on the cheapest economy oil they can find and the car is fine other use to grade synthetics it is a matter of choice and your car, older cars are more tolerant in some ways.
If that is what you think then, that is what you think, I am not here to change the way you think, I have ran my Fiat on Saab concetrate n tap water for over 7 years and 150K without a problem, I am still on the same water pump so I don't care, the Renault runs on Renault premix coolant which I have stuck with for again over 7 years no problem, all the tecs here never mix anytihng with premix it is not the done thing, but as said if you think it is fine, ok! I reckon the chap with the R8 is wishing he read his handbook, and will be by next week definatly when he gets his answer from Audi.
At the end of the day Daviedaly has only water in his system so the conversation about mixing premix does not come into it he needs some kind of anti freeze in it, which hopefully he has in it by now, if you want to mix anything with premix coolant then that is up to you, I would not advocate it myself, all I would say is read the can, it tells you on it what you should do if you have bought a decent premix, if Fiat have come with a premix already in the car from new, read your hand book it will tell you what to add, the makers of the premix and the car manufacturer do know best.
Put even more simply look up mixing bleach and toilet cleaner, two totally safe products to use by themselves, put them togther in your loo bowl and!!!! Look it up on google.
Not the same as mixing anti freeze with premix but never the less two safe chemicals, anti freeze could easily turn your premix into and acidic liquid which eats gaskets and and alloy it finds inside your engine, as Mr. R8 has just found out!
