Hi guys neeed heeeelp or i'll push my fiat over a cliff.:bang::bang::bang:
Fiat Brava 1.6 16V 1996.
Ok here goes:
I went to work today had to do some trips with the car, ran fine. Then i let the car on the side of the road. Bought a lambda probe today and went to change it, here comes the problem: Started the car and it was very hesitating meaning the revs got up to 1500 but started droping to about 1000 in about 15 sec,and up again but very uneven run, i was barely able to drove the car in the court of my bureau.
After i changed the probe the car wouldn't start. I can smell gas, i put someone to crank the car and all the leads have spark, but it fires (now and then) runs a little and then dies, done this game almost to the point were the battery is dead, o and if i try to press the gas pedal the rpm goes down instead of up.:bang::bang::bang::bang::bang::bang::bang:
Had the following things changed all new:
-water temp sensor (2 wires - the one for ECU)
-air temp sensor
-coil pack
-rpm/tdc sensor (i forgot this one)
-lambda probe
Cleaned the following:
-the whole throttle body including the position sensor
-idle speed actuator
-grounding point (the one near the coil pack)
-big black connector underneath the battery
Sry for the mistake in the title. "Brava not starting"
Ok here goes:
-air temp sensor
-coil pack
-lambda probe
