Hello everyone
Very new to this so if someone has posted similar in the past you'll have to excuse me.
The car is a '96 Brava 1.6 sx which runs pretty well most of the time. However, when it starts to get warm, and driving in traffic, the engine idles at an incredibly low speed and stalls quite a lot. when I try and re-start the starter motor struggles to turn the engine over, and when it does start the rev's are again very low and unless I keep light pressure on the accelerator it stalls again.
The following have been checked and found to be in good working order:
Cooling system, both the level and function
Starter motor is fine
Battery and charging system fine
Oil levels are ok
Just been serviced so plugs,etc are fine
Called Green Flag out but by the time they arrived it had cooled down and started first time and engine running normally. Their mechanic hadn't got a clue and could only suggest that it might be an engine management problem.
Any suggestions would be gratefully received.
Oil levels are ok
