bought it for the gf yesterday,
from a family member who couldnt afford to reinsure t&t it
anyway
the battery was knacked so stuck mine on and first crack it started no prob after about 6/7 months stood
(hope the battery is knacked or my cousen has broke my charger the t*t)
rear drums were stuck on so gave it some stick and off it went
front brakes not such a good story they work good but grind a bit prob tore pad off or there full of sh!t, and steering not as loose as i would have liked
expected all that really basic service stuff and maybe bleed the systems wouldn't surprise me if i don't even need new brakes just a good refit/clean unless i damaged the rear drums but hey there only drums or maybe it wants a front bareings (usually do that anyway on cars i get) but i doupt it
lovely gear change,
first think will just put it in for a mot and see what that throws up then ill post up for some help on bits and bobs if needed allready spotted a few threads but nothing seems bad so far
did hear water slohhing noise in dash prob air or lack of been looked after i hope
washer jet on one side not working and need radio code,
info on what oil will change it and filter if needed dunno if should risk adding to whatever is iin there not 100% knowing
slow electric passenger window
as said 1st thing 1st mot time
having trouble getting her insured (will make a seperate thread on that tomoz) so prob swap mine over to get the tax if it passes
if anything else crosses my mind ill ad to this post
anyway
lovely gear change,
