| | Thread Tools | Search this Thread |
Posts: 282 Thanks: 13 Trader Rating: 1 | Cambelt change Was gonna get the cambelt changed on the bravo. Is there anything else i should get done at the same time?
| | Quote
| | #2 |
Posts: 9,738 Thanks: 365 Trader Rating: 0 | Re: Cambelt change So.... Water pump, cambelt idler/s tensioner, coolant, cam-cover gasket. IMO it's worth doing a good full service at the same time if a service is due or the last service date is unknown.
__________________ Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium. |
| | Quote
| | #3 | ||
Posts: 282 Thanks: 13 Trader Rating: 1 | Re: Cambelt change Anything that needs the cambelt disturbed to check / replace so you dont have to do it 2 or 3 times... So.... Water pump, cambelt idler/s tensioner, coolant, cam-cover gasket. IMO it's worth doing a good full service at the same time if a service is due or the last service date is unknown.
| | Quote
| | #4 | ||
Posts: 282 Thanks: 13 Trader Rating: 1 | Re: Cambelt change Is it hard to change the cambelt yourself on a 1.6 bravo or is it best left to someone who knows what there doing.
| | Quote
| | #5 |
Posts: 9,738 Thanks: 365 Trader Rating: 0 | Re: Cambelt change Depends on your skills, workshop available, tools owned, experience, confidence... I chose to have it done properly & took the £10 Gates warranty offer when I had my Grande done.
| | Quote
| | #6 | ||
Posts: 173 Thanks: 2 Trader Rating: 0 | Re: Cambelt change IMHO all belts should be thoroughly checked and replaced if need be. The water pump system should also be carefully looked at - I've had mine replaced a few months ago as it was causing engine coolant leaks.
| | Quote
| | mahol | Punto (Mk2/2b) | 20 | 09-02-2010 20:53 |
| | Wilqaeda | Marea | 4 | 13-10-2009 11:20 |
| | Singh! | Punto (Mk2/2b) | 3 | 15-09-2008 09:39 |
| | gaz.d | Ulysse | 12 | 31-03-2007 18:19 |
| | Muttley | Stilo | 6 | 16-11-2005 09:36 |
