scottishseicento scottishseicento Parked in the garage Written a guide Joined Aug 3, 2009 Messages 331 Points 198 Location Scotland Sep 8, 2010 #1 Was gonna get the cambelt changed on the bravo. Is there anything else i should get done at the same time?
Ffoxy Telford's Own... Joined Apr 26, 2007 Messages 13,617 Points 2,161 Sep 8, 2010 #2 zzz said: Was gonna get the cambelt changed on the bravo. Is there anything else i should get done at the same time? Click to expand... Anything that needs the cambelt disturbed to check / replace so you dont have to do it 2 or 3 times... So.... Water pump, cambelt idler/s tensioner, coolant, cam-cover gasket. IMO it's worth doing a good full service at the same time if a service is due or the last service date is unknown.
OP OP scottishseicento scottishseicento Parked in the garage Written a guide Joined Aug 3, 2009 Messages 331 Points 198 Location Scotland Sep 8, 2010 #3 Ffoxy said: Anything that needs the cambelt disturbed to check / replace so you dont have to do it 2 or 3 times... So.... Water pump, cambelt idler/s tensioner, coolant, cam-cover gasket. IMO it's worth doing a good full service at the same time if a service is due or the last service date is unknown. Click to expand... Cheers foxy
OP OP scottishseicento scottishseicento Parked in the garage Written a guide Joined Aug 3, 2009 Messages 331 Points 198 Location Scotland Sep 9, 2010 #4 Is it hard to change the cambelt yourself on a 1.6 bravo or is it best left to someone who knows what there doing.
Ffoxy Telford's Own... Joined Apr 26, 2007 Messages 13,617 Points 2,161 Sep 9, 2010 #5 Depends on your skills, workshop available, tools owned, experience, confidence... I chose to have it done properly & took the £10 Gates warranty offer when I had my Grande done.
skaramazoo New member Joined Apr 9, 2008 Messages 175 Points 25 Sep 10, 2010 #6 IMHO all belts should be thoroughly checked and replaced if need be. The water pump system should also be carefully looked at - I've had mine replaced a few months ago as it was causing engine coolant leaks.
