BravaNorway
- Aug 15, 2010
- 5
- 2
Hi.
I recently acquired a 1997 Brava 1,4 12valve with cam failure (one lobe had 5mm ground off, giving almost no valve lift). I bought a cam kit and started what I thought was an easy job (looked that way...).However, when I was trying to fasten the new cam, the treads in the head (for 4 of the cam fastening bolts) gave way even before the cam came in contact with the head, leaving me with no other option than to get new thread inserts. I didn't have this possibility in my garage, so I had to dismantle the head and have it delivered to an engine workshop close to me. (which also meant having the head milled, so it got a bit expensive). Now, everyting seemed to be good. The cam was fastened with the right torque and everything was lined up by the markings. The car started, and the revving sequence was performed to adjust the new cam to the engine.
However, after this was finished, I let the throttle down to idle speed and the engine immidiately died and would not start again. The following day, the engine started up and sounded quite good, but when it started heating up, it got worse and I had to keep it on high revs to avoid it stalling. :bang: It also sounds odd, like there's something wrong with the ignition: sounds like it doesn't run on all cylinders when hot, and there's a "bopping sound in the exhaust. (but only when hot)
It seems like it has no problems running when cold, but as soon as the engine temperature rises, something goes wrong. Has anybode got an idea about what this could be?
