1.4 12v Bravo '98.
My AC never worked but today i went out to try to find out why.
it turns out that the wire that comes to the compressor in the engine bay doesn't have any voltage on it when the ac button is pressed or otherwise.
this tells me that there is an electrical problem on the circuit.
probably a fuse or a relay.
i have tried to see if the compressor engages, making a direct link to the battery "+" and YES it does. so the compressor is fine.
I need to know where all the relays and fuses of the AC system are, ( what colors.. etc a picture is worth a thousand words).
One more question:
When the ac engages the fan on the radiator should also start to rotate even thou the engine is not at optimum temperature?
I would appreciate any help in solving this problem.
One more question:
